After installing my Perrin turbo inlet and the removal of the PVC valve I routed the PVC line to the head vent catch can already in place. As I read there needs to be a dual can setup but the Perrin inlet only has one intake nipple in which the head vents are already attached to. I did a T pre catch can and now I am concerned and looking at the AOS from Grimmspeed. I need to collect funds so what can I do until funds come in for the Grimmspeed? I have a Home Depot AOS for the head vents in place now so do I just need another? But, where do I attach the line to the inlet? Should I just block off the PVC as I read with the Crawford unit? I can run to Home Depot tomorrow and set something up until funds come in for the Grimmspeed AOS but I need direction for a fix until then.
TIA
TIA
