I finally had time and installed the front sway bar from Perrin on my 09 FXT. The frame brace bolts were much easier to remove with a breaker bar as another member told me, he was right..
I also found I didn't really need to remove the plastic under cover, just removing the rear most bolt and pulling it down gives more than enough room. Also suggested by another member, I did this on ramps.
The Perrin end link kit was easy to install, about 1000 times easier to work with than the stock end links which totally suck. The stock method (5mm hex with a nut) is a PITA I think..poor design.
I went with the soft setting for now, as the rear is on the middle setting, I'm going to drive for a few days and then switch both to the stiffest setting and give that a few days. Once I'm settled on a setting, it's going in for an alignment.
Here's a link to a bunch of pics.
MobileMe Gallery
MobileMe Gallery
