End of sway bar should be above the mounting point on the control arm, endlink should be verticle. Thats basically setup the same as a "flipped" rear swaybar.
Hey everyone have an 11 forester x limited and doing the poor man 2012 wrx Oem takeoff lowering setup . I’ve seen issues or discussions of the rear upper control arm hitting the body due to being a straight arm compared to the wrx arm having a downward bend. I have seen in person the difference...
Hello all! This is my first post on this forum and I did try to search but found nothing so here it goes....
Just purchase a new '19 Forester and I can't leave anything alone. The wife and I want to lower it badly but no one has done it yet! All the coilovers I find are listed up to MY18 but...
Here is some feedback on the two types of subframe bushings I have tried. Perrin subframe lockdown kit bushings PSP-SUS-530 and the Whiteline subframe bushing inserts KDT938.
Went with the Perrin first but wasnt happy with how they sat when installed. My issue was when they were torqued down...
Thought I would post some pictures of the ReadyLift I just put on my 2019 Forester. This lift is a lot less than others and was wondering how it would all work out. - Ended up very happy. Alignment went just fine and the BFG 225/65/17 Tires fit totally fine, no rubbing. Ride is great. I was...
I have replaced both front control arms at 66k. No issues until replacing the pinch bolts on the back of the hub. I cannot get the bolt started on either side. I have even purchased new bolts from Subaru. Any suggestions.
Thanks.
