2018 Forester XT
Its a 2018 FXT, with 20,000 kms done. Post 2nd oil change (Full Synthetic 5w-30) & tire rotation, I'm experiencing sluggish performance, especially after reaching 80KMPH, i've to accelerate hard, the speed slowly climbs up to 100kmph. Also, i notice a lag in the power delivery and I get a feel of pressure leak. Has anyone come across this issue? Any help, really appreciate it?
· Premium Member
There's nothing I can imagine directly related to a tire rotation or oil change that would cause any such symptoms unless a tech did something unusual with regards to doing some inspection tasks. My advise would be get it into Service.
2018 Forester XT
Thank you for the response, I visited service and they changed the engine oil and air filter which solved the issue.
The previous oil change was done at Midas, they used Eurotech 5W-30 and I'm not sure what filter they used. As per Subaru service the filter is the issue, some of the aftermarket filter's has these issues.
2017 Forester 2.5i CVT
The symptoms you describe sound more like a partially clogged air filter than an oil filter, though cheaper generic oil filters cannot flow the Subaru high volume oil pump without maybe going partly on bypass. I also buy the OEM oil filters, if a case of 12 at once, works out to about $3.35 per filter with Quirk Auto on e-bay, outrageous.
· Premium Member
Oil filter will never be an issue. The bypass setpoint is also not a problem. Fram Ultra Synthetic is the best oil filter, bar none. Filters at 20 Microns vs 30 to 40 for most brands.
