1 - 2 of 2 Posts
2006 Subaru Automatic
Forrester 2006 ... Passenger side tail light and parking light do not go on when they should. Brake light, signals, everything works except two rear passenger running lights.
I saw on similar thread that ground wire may be culprit. Where is that located? Any other suggestions happily received.
Thanks.
2011 2.5x Auto
No tail light
The tail (parking) light filament should be in the same bulb as the brake light. Check both filaments electrically; a visual check is not good enough. Or try a new bulb.
If the dual filament bulb is OK, then check for any corrosion in the socket.
1 - 2 of 2 Posts
