2007 LL Bean
My wife a 2007 Forester. I noticed today the headlight (low beam) was out, so I replaced the bulb. Headlight still does not work. Both bulbs work when swapped in to the drivers side low beam. Any ideas on what my problem might be?
Thanks for any help.
Scott
sounds like a connection issue. I would try look on the plug for corrosion. If not then you have some other electric problem
2007 LL Bean
I am embarassed to admit this, but lesson learned don't get in a hurry even when its -10 degrees. Passenger low beam was the bulb out. I changed the passenger high beam bulb. Now that have changed the low beam bulb no problems.
2017 Limited
Kudos to you for finding and fixing the issue without giving up. Never be embarrassed on this forum, we appreciate your candor.:Banane35:
