1 - 15 of 15 Posts
2005 Forester XT
So today I go into the garage and notice a large white house paint spot on the top of the car. I look up and realize that the painters put a piece of siding with wet paint up in the rafters of the garage. :yell:
It then proceeded to drip onto the roof of the car. Its not terrible, but it's still noticable.
Does anyone know a way of removing the house paint without damaging the car paint?
Thanks for the help!
admin
How big is it?
Amusing it is fresh latex paint, try softening the paint by applying a water soaked rag and letting that sit overnight. You may be able to scrape it off with your finger nail after it softens.
Fresh oil based paints are easily removed with solvents. I'd start with plain old WD40.
Good luck,
2005 Forester XT
Thanks!
Its about an inch and a half in diameter
How big is it?
Good luck,
2005 Forester XT
Discussion Starter #7
i tried getting it wet and stuff, but it seems like it is "fused" (for lack of a better word) onto the surface. When wet, it sort of fades, but then once it dries, the white color comes back
02 Forester L (sold) Manual
You may want to swing by a body shop. They are used to things like this, even removing road stripe paint which is really tough. They have some chemicals that may clean it right off without marring the finish.
admin
You might want to try and soak overnight in WD40? It won't hurt your paint.
2005 Forester XT
Discussion Starter #12
turns out that It wasn't in fact paint. I had it looked at by a few people and they suggested that it may be acid rain? or something of the sort.
It pretty much just looks like a dry water spot that will not go away.
What would be the solution to fix that? Get it buffed?
Whatever chemical you go with (after all these suggestions), don't forget to polish and wax that spot again.
This thread is making me cringe! Any time I have to make any corrections to my paint I get swirls all over the place. I know black paint can be rough to deal with, but I'm pretty sure the Forester paint is rather soft...
1 - 15 of 15 Posts
