Is the code my 2002 Outback with the 2.5L (150k miles) is sending. I seen one mention on the web about a recall on this sensor (Atmospheric pressure sensor), bought the subby used so I don't know if any work was done in that area. Don't know if it makes a difference that I live at 9000 ft or not. Not sure what needs to be done to get it to stop showing this code.
Also over the last few weeks its been over heating and puking coolant thru the reservoir tank. Replaced the rad cap and going to get a t-stat and housing soon. Not seeing any HG leaks, no bubbles or oil in the coolant that I can see. Its not been filled with Subaru's "special" coolant or additives as I did not know until reading some of the posts here that it would make a difference.
