2005 Forester X auto
Hi all, my wife and I just purchased our first forester, I have always been a suby fan, used to have an svx but started to get I to the off-roading scene and toyota land cruisers (my other favorite).
Anyway, we just purchased this forester X a couple weeks ago, 2006, 95000 miles, 5 speed. It threw a code the other day but I just reset it with a battery disconnect to see if it came back up, which it did. I got it read and I'm getting P0303, cyl. 3 misfire. It seems to run fine, whether the code is thrown or not. I read some stuff on what it could be but don't want to throw a bunch of money at it as registration and everything else paying for the car cleared us out pretty good. I just want some tips on where to start, I'm going to do plugs for sure to start with, but is there anythin else I should look at? What else could cause this code but not show any signs of bad running (no rough idle, etc?). One more thing I should mention is I'm using ethanol free 91, I'm pretty sure the po was using 10% ethanol as that is all that is available nearby except the one place I get the ethanol free from. I read that they can be picky with fuels so thought it may be worth mentioning.
Thanks for any insight!
2003 FXS Auto
I just P0301 (missfire cyl 1). I pulled the plugs and they were very worn with a .070 gap. The new plugs made a big improvement, but judging by the condition of the plugs I should have realized the plug wires were probably in need of replacement too. I bought the NGK wires from Amazon.com for $45.82.
2014 2.0XT Limited CVT
Step up one level to Forum and search on P0303. Lots of messages and advice about the error.
Thanks for the help, I got another code today, p0304, I pulled one of my plug wires and found oil, guess I'll be doing the seals and valve cover gasket soon! Pretty sure this is my issue.
Just an update in case this post can help someone else, I replaced the spark plugs, valve cover gaskets and spark plug gaskets and haven't had another code in 500 miles.
