2004 Forester XT
I've got a cylinder 2 misfire after changing the spark plugs. I don't know which cylinder that is. Is that the back cylinder on the right hand (driver's) side or on the other side? I went through and tightened the plugs some more and now I don't have the misfire error until I get up in the higher RPMs. Could this point to a sticky injector as well? Please help!
2014 Impreza Ltd CVT
P0302 is cylinder 2 .... Left Front by the battery.
If you are in the US/Canada .... Drivers side front
UK/Japan Right drive ..... passenger front.
Be certain you don't have a bad wire since it happened after you changed the plugs.
2004 Forester XT
I put in a known working plug and tried different coils and still go the same error. scantool says it's a cyl 2 misfire and proscan says it's a p0326 knock sensor problem.....
2004 Forester XT
I resolved the issue! The problem was with the ignition coil connector. I look at the connectors on the plug and one was farther back than the other two. I pushed it in and it works without a problem now!
