P2006 Error Code
OK, no responders yet, but I did some more research. In order to test the wiring harness I'll need to disconnect the lead at both ends, one at the VVT, other at the ECM. Once done, I can then run a test to determine if the harness is shorted.
Been looking for wiring diagrams on-line, but no luck so far. Does anyone out there know which plug I'd need to disconnect from the ECM to disconnect the intake VVT?
Aside from that, oil level needs to be checked....done and OK. Since I just replaced the valve, unless it is faulty out of the box, I should be OK there....I will run a continuity test on the new VVT just to be sure.
Beyond that I could also have a problem with the ECM. This would require more instrumentation than I have at home and I'll probably need to bring it to a shop for proper testing.
