50/50
Did you dilute the coolant to 1:1 or use a 50% pre mixed? If you used 100% concentrate the engine will overheat.
Water pumps usually fail when the impeller shaft bearing goes. The pump leaks and makes a horrible noise at idle. You should first pressure check the system to locate any leaks to 15PSI. Hopefully a blown head gasket isn't allowing exhaust gases to displace coolant and overheat the engine. Unfortunately, the most common reason a Subaru engine overheats
I use a brand name or nothing at all. On Stant they have really good quality and cheap stuff. If you use Stant request the X-act stat. It looks like an OE re-box. Brass center, larger spring and probably twice the heft.I used the Auto zone Duralast brand with no issues.... I'm thinking I should use that one again on hers...
ThisSpend the $$ and get a factory Subaru unit.
yeah, that's the one that I ordered... X-act stat P/N 48457... You're darn right about the weight on that thing... I had to use some clear gasket sealant around the gasket just so it would stay in place for a few seconds.. enough time to stay put when I was trying to screw in the bottom pipe attachment... SOB kept falling out into the coolant drain tub..I use a brand name or nothing at all. On Stant they have really good quality and cheap stuff. If you use Stant request the X-act stat. It looks like an OE re-box. Brass center, larger spring and probably twice the heft.
FYI - Save yourself the trouble next time. Just alternate dumping in each in half gallon increments. The coolant will be well mixed within minutes of starting the car.I meticulously and precisely mixed a 50:50 solution of distilled water and coolant concentrate. I mean I took an empty 1 liter water bottle, poured distilled water to the brim, did the same with the coolant in another 1 liter bottle... and poured them both into an empty coolant jug, and shook the crap out of it, and THEN poured it into the radiator. I repeated this until the radiator was full.
I would like to do it your way, however, what if the last half gallon you put in is of coolant, and there is no more room to add distilled water to bring it to a desired 50/50 mix. I always want half and half... call me crazy, or just call it a personal preference, I don't care.FYI - Save yourself the trouble next time. Just alternate dumping in each in half gallon increments. The coolant will be well mixed within minutes of starting the car.
They cycle on and off..I think from 203F to 200F. If you have an OBDII you c\should see that. They will do that even without A/C onWhen I have it parked and idling, the fans are not switching on unless the A/c system is operating... is this normal given the cooler ambient temperatures in this time of year?
On my Foz, the fans do the same thing... cycle on and off only when the A/c is on. Since the fans are controlled by the Coolant temperature sensor, (am I right?). Could it be that this needs to be replaced? How can I test it for function??
