Help with parts list to overhaul ej251
Hello SF!
I had started a thread before but I didn't know enough about my car. My '01 Forester which has 114K miles overheats, most likely due to the typical HG failure. I've decided to do a complete engine overhaul, not just the HGs. Since I'll be removing the engine, I might as well take it apart completely and change every gasket, seal, packing, O-ring, and everything that warrants replacement while I'm doing this job. Previous owner installed a new timing belt, changed the water pump and the pulleys as well as a new thermostat, but overheating issue continued(those parts I'll be just checking over). I will be machining the heads as well to make sure everything is straight.
I've never done this before and would appreciate if you guys can point me in the right direction in regards to a list of the parts needed. Here's the list I got so far:
Piston rings (3 for each Piston)
Connecting rod bearings (replace these??)
Crankshaft bearings (replace these??)
Circlip (replace these??) snap ring that holds Piston pin
•Cylinder Head Gaskets (2)
•Valve Cover Gasket Kit -Front Cam Seals (2)
•Front Crank Seal
•Rear Main Seal
•Water Pipe O-rings (2)
•Intake Manifold Gaskets (2)
•Exhaust Manifold Gaskets (2)
•Oil Fill Neck O-ring
•Rear Cylinder Head Plugs (2)
•Rear Piston Plug O-ring
•Oil Filter and Crush Washer
Head bolts(planning to reuse them) just changing the washers, is there a parts number for the washers?
Block bolts(do I have to replace these washers as well?)
Dowel alignment pins(anyone has the parts number in case I damage these when I remove them?)
Specialty Tools needed:
Crank Pulley tool
Crank Sprocket tool
Kindly, please point out anything I might have missed. Thanks
Hello SF!
•Front Crank Seal
•Rear Main Seal
Crank Pulley tool
Crank Sprocket tool
