1 - 17 of 17 Posts
so a couple weeks back, i noticed my coolant tank to be low so i filled it up. but i think i filled the reservoir tank too much. now i noticed little coolant spots on the top of my radiator which looks like little leaks coming out of the top. Im thinking its from too much pressure from over filling. my temp gauge doesnt say im overheating nor do i notice any decrease in performance.
ok so my question is, do i need to replace the radiator or is there a way to seal up these leaks?
and if i do need to replace the radiator... how important is it to get the 300$ alluminum one vs the basic 140$ one? does it make a difference in performance? will one last longer than the other? any help/ suggestions would be appreciated.
2014 328i xDrive Wagon 8 spd Auto
What year? The worst that should happen from overfilling the plastic expansion tank is that it overflows and goes on the ground when it gets hot. If that's what you did, I doubt it caused your problems.
the only other thing i did with the radiator was put some generic coolant to top it off when i first acquired the car back in december 2009.. could it be a bigger problem that caused it?
Smooshed FOTY 2011
lol. No, you are fine. There is no such thing as over-pressurizing the coolant system by overfilling your over-flow coolant reservoir. Simply take off the two 10mm bolts that hold it in place, take it out and drain a little if it concerns you that much. What I'm thinking that happened is that when the car warmed up, the coolant expanded, causing the over-flow bottle to become full, and it squirted out the top and sprayed onto the radiator, causing those "little leaks" you mentioned.
Just wipe off the radiator (because it's fine, nothing's wrong with it), drain some fluid from the reservoir and get it to the correct level.
2001 Forester S
The above posters are right in that 'excess' coolant will just be pushed out of the reservoir tank when the system expands. But there should always be some left in it, even when the engine is cold (say a couple inches of coolant in the bottom). If the reservoir keeps emptying then you might have a coolant leak out the top of the radiator where the plastic top tank meets the aluminum. That is why your coolant was low in the first place. Do you smell coolant while you are driving?
You should get the engine warm and look under the hood with a flashlight while the engine is idling and the system is at pressure. Look for any places where coolant is leaking. (Be very careful - don't go prodding any hoses or take of the rad cap as the coolant is very hot and could scald you.)
2008 XS 4EAT
All the replies have posted the correct answers, but what would have really helped is knowing your year and model, which would have likely elicited different possibilities. I had to search through some of your earlier posts to find that you have a 2004 FXT from parts that you were selling.
Take some time and add some vehicle info to your Signature. Use the pull-down menu in Quick Links, Edit Signature and add basic info like, year/model/transmission this will show up every time you post and will usually help people better respond to your questions without repeating yourself or leaving info out.
You might have gotten responses like this http://www.subaruforester.org/vbulletin/f88/cracked-radiator-44646/ seems it's fairly common on the earlier XT's as additional threads show.
Hope this helps you, if this could be the possible cause.
Cheers
it did overflow in my reservoir. so i cleaned all the coolant that got into the engine.but, after a few days, i noticed that the top of the radiator where the plastic meets the metal brace, there is coolant seaping out of the cracks. so does this mean i just need a new radiator? im just afraid because i drove the car like this for over 2 weeks. could this have caused a blown head gasket?
Smooshed FOTY 2011
First, if you had a blown head gasket, you would have known already. An no, driving around with a small leak in the coolant system doesn't cause head gasket failure. (unless your temp gauge was pegged out at HOT and you continued to drive), but if your temp gauge was showing fine, you have nothing to worry about.
If it's seeping out from between the plastic and the aluminum, then yes, you're radiator might possibly need to be replaced. You can get an OEM one or do what I did and find a local shop that might have one. I found a replacement in my town for $128 bucks, and it's been going strong for the past 10,000 miles of abuse.
03X MT
b4 you do anything drastic make sure the ex bottle is not too full. Have just 2 inches or so cold and then get the engine up to temp. Also take a look at the rad cap.
2010 Forester
Pick up a turkey baster (spelling?) at the supermarket for around $1.50. Really handy for undoing overfills of most anything.
NO...do not use the one from the kitchen drawer!!!:crazy:
2004 FXT Premium 4EAT
If I were replacing my radiator, I'd replace the cap as well.
What part of the Bay Area are you from? I grew up in Los Altos (a very long time ago.)
David
03X MT
So, you are replacing the radiator b4 you know for sure that the coolant you saw was not from an improperly filled coolant reservoir?
Well then, you might as well get all new hoses, belts etc while you're in there. Then you won't have to mess with it for 50k miles.
2010 Forester
Could you recap why you are changing the radiator. This is an expensive item and never fun to install, and you haven't told us that it was actually leaking. Please describe what happened. It almost sounds like you went from needing a turkey baster to remove coolant to a $500 job! Did I miss something?
As was said, if all the hoses etc are original, by al lmeans do it all while you are doing the radiator so there wil lbe less ways for your new coolant to find a way out.
No hose lasts forever. Personally, iI like to change hoses and belts by 6/60 to avoid problems.
Discussion Starter · #17 ·
thanks for the replies everyone. i figured out that my radiator was cracked. about a 2 inch crack near the top hose inlet. but bought a replacement radiator from a friend that worked at winchester auto for 140$ ( alluminum oem replacement, made by CSF?) new coolant 15$. put the new radiator in in about 3 hours. so got away spending only 155$ and an afternoon of my time..
1 - 17 of 17 Posts
