1 - 16 of 16 Posts
01 UK S-Turbo AT
as per attached, sits underneath handbrake lever. dense rubber, looks like a magnet????
am I clueless or what!
no access to parts cat on my iPhoney so clueless...
cheers
mike
MY11 WRX STi Sedan 6MT
Parking Brake switch.
01 UK S-Turbo AT
Discussion Starter #4 (Edited)
How the hell does that work then? There is no obvious other part to make contact/block signal/otherwise.
Intriguing.
cheers Don ;)
mike
EDIT: Don. I don't supose you have a sectional diagram of same, would you..?
TANSTAAFL
2010 2.5X Premium AFF 4EAT
Intriguing.
cheers Don ;)
mike
From the looks of it my guess would be, it's a magnetic switch. Is there anything metallic close to it when the handbrake is operated?
Exactly..........
01 UK S-Turbo AT
Discussion Starter #7
not sure, can'r see anything other than a metal fame for the handbrake rubber surround.
interesting. Kinda.
mike
01 UK S-Turbo AT
Discussion Starter #9
cheers mate :)
evidence of previous dog owner :( always wondered why the INSIDE of the rear glass is scratched!
I also found a pound and 20p, a small pink heart-shaped sticker and something that if "job" had found, would have ended up with me being arrested and cautioned probably....!
nuff said ;)
2002 SG XT Auto
Thats a birds nest/fluff detector, and i think it's found one.
Sorry for the mislead...........
After closer inspection of the picture and seeing more than one wire attached to it, a rummage through the wiring diagrams points to it not being the parking brake switch but an ABS G sensor assembly as shown here item 6..............
http://opposedforces.com/parts/fore..._system/antilock_brake_system/illustration_2/
A better illustration of its location for the FXT version here..........
http://opposedforces.com/parts/fore..._system/antilock_brake_system/illustration_3/
Mad Englishman.
MY06 Forester STi 6MT
Did we just witness Don make an error...?
:mob:
Is anyone else thinking we should remove his lifetime membership...? :chair:
:raspberry::raspberry::raspberry::raspberry:
:mob:
:tissue::tissue::tissue::tissue:
01 UK S-Turbo AT
Discussion Starter #15
yes, good spot Don :) I played wi t'handbrake today and can confirm after reading this that I found the switch was within handbrake lever assembly/
How does that actually work??
I find the position of it interesting, relative to the handbrake though. Wondering also if its location is midway between axles and central relative to wheelbase..?
too drunk to think straight following a poor game of football? probably...
mike
1 - 16 of 16 Posts
