Well so far the list is empty, its totally stock, hasn't even got floormats
but there it a long list of things planned:
19's because I cant get the rims I want in 20's or bigger unless I convert the stud pattern to 5x114.3 and I cant see that happening for cheap...
Tein super street coil overs
Full turbo back exhaust from Hi Tech
TD05H after I get it rebuilt and the correct compressor housing fitted, it currently has the inlet with the 90deg elbow cast into it, Maybe even a VF series turbo if I can stretch for it
STI top mount cooler or larger aftermarket cooler(APS or similar)
More boost :thumbs:
Short Shifter
PPG 1st-4th helical cut gear replacement set after I break the standard stuff which will probably just be a matter of when, not if
Front LSD
Maybe a RWD conversion spool if I get bored...
but first and fore most is paying the car off and doing some exterior stuff like the sports kit, mesh grill, "f" badge and Ozfoz decals
So enough about my wish list, here's some pics
OMG theres a snail under ma bonnet
Damm plastic, cant see the steel...
100.7 Zink Stinks...
Fully sick sub uleh
