1 - 17 of 17 Posts
2008 Forester XT Sport 4EAT
Wait, is Subaru UK recommending 10W-50 oil? That's the first I've seen of that.
EJ engines over here are recommended to use 5W-30.
I use 5W-40, but I'm about to try 0W-40 for the winter.
A lot (if not all) Subaru specialists recommend 10w-50; it is also mentioned in the document.
Garages usually buy one grade of oil in bulk for cost saving, best to use what you think is best for yor own engine.
2004 FSTI 6 MT
99 UK S-turbo
10w50 may be recommended, but why........I suspect many don't really know.
Indeed. I suspect for a higher mileage car, a forged engine or one that is used hard on the track it makes sense.
I stick to 5w-40 in mine although I have used 10w-50 in summer and during trackdays.
Emeritus Forum Staff
This is what S4U claim.
i thought we were supposed to use 10w40?
I'll probably be flamed for saying it but the most important thing is that it's good quality, high ester, fresh and there's the right amount of it IMHO.
Discussion Starter · #13 · (Edited)
Yes I change the oil every 3,000 miles.
I stopped using Shell Helix Ultra (only used it twice) ever since I had it analysed and it was found to be oxidised.
It only reached 103C or so, so I can't explain.
Stick to Fuchs/Silkolene/Titan since then and it is fine.
2015 Fiat van Man stick
Bejesus! If I changed my oil every 3k it would be done nearly every other week! Three services a year is plenty for me.
99 UK S-turbo
I was using castrol Edge 0W30 and changing every year (about 12K miles), hardly any point paying for all the additives if you change the oil before they have a chance to be needed, engine was at 156K miles and running perfectly with regular excursions into the redline.
2004 Forester Sti 6 MT
JDM Manual for Forester STI:
SUBARU :
Full manual download here:
http://www.subaru.jp/afterservice/tnst/pdf_forester/1/all.pdf
5W30 for Turbo Foresters including STI
0W20 for Non Turbo
10W50 Elf for Hard use or hot climate
My last service I was offered 10W50 which seems a bit overkill especially for winter.
Actually when I do my own oil I use 0W30 Shell Helix Ultra as it has excellent shear properties (better than some 40W and 50W oils) and will give good cold start performance, plus is often on special offer.
I know this is 'controversial' as somehow 0w30 is thinner than 10W30, well ...yes it is at startup when you want it to be thin.
I do use a 40W oil for track use tho but could go with a modern 30W as again the protection a modern synthetic low weight oil gives is pretty amazing.
1 - 17 of 17 Posts
