1 - 20 of 20 Posts
2007 Subaru WRX TR
I know this has been covered before, but I just wanted to be 100% certain before I buy: Will 215/75/15 tires (specifically BF Goodrich Mud-Terrain T/A KM2) fit on an SF Forester with SG rear struts?
Thanks for the help in advance!
02 Foz 4eat
I am running 215/70/15 General Arctic Altimax tires on my SF with SF KYB struts and its tight, with the struts and with the fender opening. You can probably fit a 215/75, but it will be snug.
2002 SG XT Auto
Dunno if they'll fit, but i wanna see pics if they do.:rock:
2007 Subaru WRX TR
I have ordered the tires and I will take pictures and post them up when I get them on the Foz!
2007 Subaru WRX TR
Wow, your Forester looks wicked nice!
Here's a picture of the rims and tires that will be going on the Forester on Monday:
2007 Subaru WRX TR
Got the tires mounted and balanced and then went and got an alignment. They just barely fit. Here's the pictures:
2006 2006 & 2010 Forester automatic
I want to know...
How much it tanks the MPG...(mud tires aren't exactly MPG friendly)
If our '06 becomes a full time farm office(my cousin who owns it wants a newer car...finally), it will need off-road tires.
2007 Subaru WRX TR
Discussion Starter · #10 ·
I'm planning on checking the next time I fill up. I'll let you know!
02 Foz 4eat
That is snug, but looks good. Are you running 1" spacers all around and taller springs?
2003 Forester XS
I don't want to hijack the thread but I was wondering about taller sidewall tires. Since our '03 XS uses 215/65/16s I was wondering if the taller sidewall just gave more cushioning for off road since there is more air volume in the tire? Do you run the same PSI? Just a simple answer - no hijacking - thanks!
2007 Subaru WRX TR
Discussion Starter · #13 ·
I have King Springs (~1.4" lift) on it with 3/4" rear & 1/2" front spacers. I'm also using SG struts for more room in the back (spring perch is higher than on the SF strut).
By no means am I going to pretend I'm an expert at offroading, but from what I have read, having a taller sidewall allows for more grip on rocks/sand when you lower the air pressure of the tire. I believe it also gives more cushion between the hard surface you're driving on and your rim (think about offroading with a low profile tire, yikes). I think the cushoning benefit comes from increasing the tire's compressibility by lowering overall pressure inside the tire, while still keeping the rim and sidewall protected.
I also liked the skinnier tire (215/75) because it should perform fairly well in snowy situations as well as off-road.
So far I've been running 28PSI, but I'm going to test the MPG with that and then inflate to 30-32PSI to see how much the MPG changes. If I was going to be doing some serious time offroading then yes I would deflate and reinflate after I was done. Hope I answered your question!
2007 Subaru WRX TR
Discussion Starter · #14 ·
After about a week of driving it looks like I'm getting between 22-24 MPG in mixed driving ~(70% Highway, 30% City). Not really all that bad considering the size and weight of the wheels.
2007 Subaru WRX TR
Discussion Starter · #16 ·
I used 03 struts... however, you have to change the way the brake line is affixed to the strut tower.
Smooshed FOTY 2011
Nice! One of these days I'd like to put on some mud terrains.
1998 Forester L
hate to bring this back from the dead but ha=ow did the KM2's work out for you?did you "have" to change the rear struts to the SG's or would it have cleared without?Also were the wheel spacers necessary ?
2007 Subaru WRX TR
Discussion Starter · #20 ·
Here's my opinion of the KM2's:
If you spend a lot of time driving at highway speeds, I don't recommend them. They are loud and it gets old after awhile. They also don't have the best wear characteristics (at least, how this particular set wore on my 2001). They weren't great in snow, but I've driven on worse all seasons before.
IIRC, I did have to change the rear strut as the tire wouldn't clear the perch... as it was, it was a very tight fit.
The spacers I referenced were a strut lift - I didn't need to use wheel spacers.
1 - 20 of 20 Posts
