To start off, I did search the forums for Oil Pump threads, but couldn't find any threads dedicated to this part. I'm hoping that's a good sign...
I'm in the middle of a HG replacement on a SOHC EJ25 (240k miles) but also looking over everything else I have access to. I pulled the Oil Pump and was planning to disassemble it for inspection, and check for tolerances, however the 5 screws holding the pump mechanism together won't budge. It looks like someone either tried or did open it up in the past as one of the phillips head screws is partially rounded out. I was careful not to do the same damage for the other screws but I honestly cant get any of them to break free and I'm not interested in causing damage or more work for myself.
I tried a regular screwdriver first, then a 1/4" drive ratchet with a #2 philips bit on a 1/4" socket. That didn't make a difference so I tried a 12" breaker bar on the socket and still cant get any of them to break free. To be fair, I don't have it in a vise as I didn't want to damage the casting. I considered an impact driver but again, concerned about doing damage either to the casting, mechanism or mating surfaces.
My question, is it even worth trying to disassemble for inspection? Is there any reason to suspect it may fail soon based on the 240k miles. So far the rest of the engine appears to be in good shape, so I have no reason to believe the pump is failing. This is just a daily driver but has spent plenty of time on the highway too.
