1 - 20 of 28 Posts
So the small oil cooler that is above the oil filter started to leak about 30,000 miles ago. I do 10,000 mile oil changes so i waited till 20,000 to change the o ring on the top of it. After I replaced that big o-ring it seemed to stop leaking for about a week then it started to leak again slowly. 10,000 miles ago i retorqued the bolt and it was at spec and have been monitoring it since. Its still leaking. Is it a possibility that the cooler is leaking between all those disks and its not the o-ring? If so is there a way to fix it or do I need replace the whole cooler?
Any info is greatly appreciated.
Just for the record, the thing you're referring to is more of an oil heater than a cooler. It helps the oil warm up quickly.
Regardless, it's unlikely to be leaking between the disks. I would replace the o-ring again, be sure all the surfaces were clean, etc. Be sure it's torqued correctly. There may be a better way to seal this whole assembly to the block - maybe coat the o-ring in sealant or the lips in form-a-gasket. Someone else please jump in on that.
You did not indicate how much oil is leaking. Is it is little - a few drips? Or is the garage floor flooded? If it's a few drips, that's a Subaru "feature".
If the OP's 06 X has an oil heater over the filter, your 05 X must have had it, too.
Then once a feature is dropped, it does not come back.
For instance, the X lost its oil heater after 06 or 07.
The 4EAT lost its fluid filter after 07
The LL Bean lost its self leveling struts after 07.
Super Moderator
Discussion Starter #10
First off, how and why is this a heater? It has coolant running through it? Why would you try to heat up oil that came from a hot engine?
Also yes, i used an oem o ring from subaru dealer. I did put oil on the ring before installing and i did torque it correctly. Also im 99% positive its coming from the cooler and not the head gasket.
Its not a lot of oil but its more than normal which should be none. No its not a "subaru thing" they are not suppose to leak.
Also yes, you can delete this but you have to replace the water pump with an older model pump and do a few other things. I actually have a brand new pump in my garage.
Super Moderator
The cooler function. The coolant temperature is lower than the oil temperature, so the heat from the oil will be transferred to the coolant.
As to oil heater. The coolant warms up sooner, so it will will help bring the oil temperature up to the normal operating temperature quicker.
The sooner the engine gets to the optimal operating temperature, the less wear & better the performance. :wink:
So there are coolant hoses to this oil heater gizmo located in the oil filter mount?
Yes, one line in and one line out. The oil is going inthrough the filter pipe. Here's a pic of a nice new one - notice the big red o-ring:
And here's one that's installed. It's already leaking ;-)
Here's an article from Outback land on how to change the o-ring gasket.
Very interesting. I can see why Subaru dropped the oil heater. Troublesome, hard to fix, and of marginal value to warm up, only in very cold climates. So glad I don't have it.
Discussion Starter #15
So back to my original question. What to do? Replace gasket again? Is there any chance that it could be leaking between disks? Only one way to find out is buy a new one?
Super Moderator
If it was me, I'd do the O-ring once more. Making extra sure the seating area is free of any debris. I'd also inspect the removed O-ring for flaws.
If you clean the entire area... make it dry & oil free, you should be able to see were the seepage is coming from. :wink:
Discussion Starter #17
When l did it last time i did as you described. Cleaned and dried whole area with brake parts cleaner. Made sure the new oring was in good shape and seating area is clean and inspected old oring. All check out fine. I believe its coming between the disks based on where oil is gathering but i will try it again at the next oil change.
Discussion Starter #19
Well its the head gasket....took the car to my father in laws shop. Put it up on the lift. Completely cleaned the area. Started it and watched as the oil pooled on the head gasket right next to the oil cooler.
Sweeeeet, awesome present from my wife for Christmas. Maybe if she didnt drive the thing like a damn race car it would last her longer a couple years.
Well it needs new valve seals anyway so it looks like i have a head rebuild in my future.
1 - 20 of 28 Posts
