1 - 20 of 44 Posts
2005 FXT/AT
Has anyone installed a OCC in an '05 FXT without the snorkus mod? If so, what Oil Catch Can brand did you use and where did you manage to find space to install it?!?
I didn't find this thread anywere during my searches. This thread is on Scoobymods.com but it doesn't answer this question.
Thanks -
admin
One thing to keep in mind is even though these shop based oil separators may work well they are not designed with our harsh under hood conditions in mind. Their intended environment is a lot friendlier than under our hoods.
My Helix can was installed at an angle along the inner pass. side fender wall, in front of the hole where the snorkus normally connects to the airbox. You can sort of see it in the lower left corner of this pic.
And no, my engine bay isn't always that dirty... ;)
helix here too...same spot as silke's. mine is empty and has collected a crapload of oil already. About 0.5-0.75in up the visible tube. glad i have it.
05 XTi FMIC
Silke.........Can you PLEASE get Subed a hanky.....Geez, thats gross...
05 XTi FMIC
Never thought of that.....Mine is in the passenger's side, far front corner of the engine compartment. I has soiled the filter but hasnt collected any oil in the capsule.....The only heat sensitive component IMHO would be the plastic collection bowl, but it is pretty thick plastic. Not sure about the inline micron filter though. I will keep an eye on it. Thx for the heads up SuperRu
2004 Forester XT MT
Excellent point. The max temp for that particular filter is 150F. Here is a link to the .pdf brochure.
2005 FXT/AT
Discussion Starter · #13 ·
OCC - interesting options
Compressor separator is very original - nice idea. I'm thinking of something a bit larger and in stainless (I love shiny things in my engine compartment!). :)
Has anybody installed the Cusco OCC (Kastle's Korner has them)? They look smaller and might fit into the FXT engine compartment w/o making the Snorkus mod.
I used to use a Fram plastic fuel filter for a catch can on my DSMs. $4 and you just throw it away when it gets half full. Should fit easily in the engine bay. They are available with top in top out nipples and the oil level can easily be read through the white plastic.
Frank
#8 Post ho
1999 Subaru Forester
Oil Catch cans catches the oil and moisture in the blow-by gas that causes carbon and sludge build-up in the intake system and the engine. It keeps the engine clean even under hard driving conditions
Oil catch can is used to reduce the oil vapours from going into the air intake charge. The oil vapours will contaminate the intake charge by mixing with the air and fuel that are used to create combustion. This catch can would reduce burn efficiency and decrease detonation risk in both turbo or Non turbo cars
13 Forester XT 4EAT
Thanks for the quick lesson. What line is the catch can installed on?
1 - 20 of 44 Posts
