1 - 8 of 8 Posts
2010 Forester
Hi all,
I'm have just over 12,700k's on the OEM Geolanders and I happened to notice something odd today. It looks as if the Geolanders are wearing unevenly - on the front two tires the outside edge of the tread appears to be wearing more quickly than the rest of the tire - any ideas?
Cheers - Steve
Smooshed FOTY 2011
.....because the front tires are used to turn the vehicle, and the outer edge is what "rolls" under rim when you turn, so naturally (as with all vehicles and all tires), the outside shoulders on the front tires always wear quicker.
Here's a picture of what the front tires do during turning. It's an "extreme" example, but similarly, the same thing goes on when driving normally around town, just at a fraction of the degree. Notice how much of the front tire rolls underneath the wheel, which scrubs the outside shoulder. The back tires still roll, just not as much as the fronts.
2015 Highlander AWD XLE 6AT
I'm have just over 12,700k's on the OEM Geolanders...
Unless you've already done it, the tires were due for a rotation at 12,000 km.
HTH,
Jim/crewzer
2018 2.5i Premium CVT
That's how it is with the OEM Geos. Lots of us have encountered this.
13 Forester XT 4EAT
Check your air pressure as well, but keep rotating every 5 or 6 K.
2007 FSXT 5MT
Dealer had the fronts replaced under warranty at 14K because the fronts had worn almost bald on the inner edges (alignment was fine). Now the rears at 19K are down to the wear bars and it just failed inspection! I'm waiting to hear back from the dealer if they will cover replacement or at least throw me a bone- it's a little unacceptable in my book for a 3year old car just shy of 20K miles to have blown through a set of tires already and fail state inspection.
Normal? It suuuuure is. Replaced mine at 22k because those portions balded at that mileage. Rotate them and you will probably get the about the same mileage.
1 - 8 of 8 Posts
