Does the light go out in your fridge when you close the door? :grin:
OK...So I suffer from a little OCD. I was curious as to how efficient the air scoop shroud was :idea: so I set up my little vid cam and a light an ran some vid as the hood was closed. Then I captured a couple stills from the vid. My question is...I am getting a larger hood scoop (02-03 Wrx STI) and was wondering if a splitter would be beneficial? (I'm keeping the stock IC). The shroud seems to fit nice and tight...don't think I would gain much with a splitter, especially with the stock IC. What are your thoughts?... On the splitter not the OCD :oops:
Closing the hood...shroud lines up nicely.
Hood closed...shroud seems to sit down on IC nice and snug. No bends/buckles/bulges.
2008 SG Model D
If you are just using the stock TMIC w/ the new scoop, the stock splitter will work fine...just follow Peaty's directions for the install:
http://www.scoobymods.com/forums/showthread.php?t=4802
NOTE: I had to use pliers on the corners when bending the top piece up to meet the inside of the new scoop but it turned out perfect and the install was super easy. Thanks Peaty!
