Hi all,
I've got a 2004 x-trim that the front 02 sensor seems to have gone bad on (P0032). I want to disconnect the sensor at the wiring harness so I can ohm the heater leads and verify the heat element is shot. But I'll be darned if I can't get that connector to disconnect.
Looks like there's a little tab on the side and when I depress it, I get a little "click" and seems like a slight shift in the connection - but it will not separate! What am I doing wrong here?
