Status
Not open for further replies.
1 - 8 of 8 Posts
2006 Forester XT
2006 Subaru Forester XT Limited - 5 Speed
Currently at 170k miles.
Regal Blue Pearl exterior with black interior.
Manual transmission and turbocharged 2.5L with symmetrical AWD.
Oil changes and some maintenance performed by myself. Major maintenance performed by shops. Receipts available.
Maintenance performed by shops:
New timing belt, water pump, pulleys, seals, thermostat at 129k
New coolant hoses, drive belts, and evaporative hose at 155k
New front axles and alignment at 158k
New motor mounts installed at 165k
Other maintenance/parts installed by myself:
New NGK spark plugs at 135k
New Grimmspeed air oil separator at 150k
New struts and 2" lift with trailing arm spacers at 155k
New headlight housings and bulbs at 160k
New front brake pads and rotors at 167k
Always Rotella T6 and Tokyo Roki filter
Front aluminum skid plate by Primitive Racing
2" Sumo lift kit and trailing arm spacers
Nvidia G200 cat-back exhaust
Grimmspeed OEM to 3 inch cat-back adapter
Kartboy 15mm black exhaust hangers
WeatherTech floor mats
General Grabber All Terrain tires and full size spare
Mishimoto aluminum radiator
Mishimoto silicone radiator hoses
Asking $7.5k OBO
Thanks for looking
2005 Forester XS
Could you post a few pictures of the undercarriage? Any mechanical issues at all, how is the clutch, oil leaks anywhere, head gasket leaks? Thank you!
-Ethan
1 - 8 of 8 Posts
Status
