2013 Forester XT
I have a brand new pair of 4 piston Nissan Sumitomo Iron Z32 calipers in 30mm with KNS adapters and Steel braided brakelines for sale. These should be a straight bolt on affair with the use of the 316mm rotors from an SJ (2015+) Forester 2.0XT. They are fully loaded with clips, pin and brake pads. These similar to the 4pot Subaru calipers are a great option over Brembos since they require less wheel clearance. Looking to get $450 for the setup. Local Pick ups are welcome. Shipping looks to be about 30lbs for the pair of calipers.
KNS install write up.
Another Review
Wheel Automotive tire Motor vehicle Tire Bumper
Automotive tire Motor vehicle Asphalt Automotive wheel system Automotive exterior
Motor vehicle Insect Arthropod Grey Road surface
2013 Forester XT
Discussion Starter · #2 ·
Just to answer a few questions I've received.
FHI Red Subaru 4 pots are use a 294mm (11.5") rotor with 24mm thickness
Nissan 4 pot/ Kartboy use a 316mm (12.4") rotor with 30mm thickness
The larger rotor provides more brake torque due to taller diameter and the thickness provides more heat capacity.
