2018 Forester 2.0L XT Ltd CVT
When opening the powered hatch on my 2018 XT Ltd there is a groaning noise. This only occurs within the first few inches of travel & is more prevalent in cold weather.
I have lubed the hinges & any moving parts of the mechanism.
Has anyone else run into this problem?
Super Moderator
2014 2.5i Limited CVT
Yes. Usually for me it is just after a wash or exremely cold. I think it is more from the power lift strut and not the hatch pressurized struts.
But hoping the sound will go away when I get TheFoz back from the dealer after they replace them [and some other work] under warranty.
2017 Forester 2.5i MT
Probably not your issue, but the mounting screws were loose on one of my pressure lift struts, and it moved enough to make a low frequency noise/groan during first few inches of opening.
The situation is resolved. :smile2:
I was at the dealers yesterday & advised them of the problem. It was just a matter of lubricating the mechanism. (I was not lubing the right part when I attempted the fix):mad: It took the tech just a couple of minutes to perform this service.
2017 Forester XT Premium
The seals on the struts will fail and give you a "whoop" noise when you open the hatch. The dealer replaced 2 sets so far and they are failing again. My father has a 17 2.5 and his are failing as well.
2017 Forester Touring CVT
Same here. On my 2nd set on my 17’
Lubing only temporarily cured it.
It will return in short order.
Also, when I hit the lift button Im getting a long delay before it starts to lift. Like I stand there and look at it waiting for it to open.
Anyone else having that multi second delay for the hatch to start opening?
