2017 Forester XT
Looking to do my first home based oil change.
There is a flat-bottomed black pan about one foot square about 4 feet back from the front of car, and another curved black pan - looks like the bottom of a doughnut, about 29 inches back from the front of the car. Each has a 14mm hex bolt. I think the front one is the oil drain, and the rear one is possibly the transmission drain. But - I've seen comments on this site describing an access plate that is inscribed with "oil drain" that needs to be removed to get access to the oil drain plug. I can't find such a plate on my car, and don't want to drain the wrong fluid. The forward plug is just rear of a sheet metal shield/deflector-like ridge that projects down about an inch.
Which is the real oil drain plug??
Thanks
2017 Forester XT
Oil change comment
Thanks for your help. Oil change fine, but messy - even with care!
So, I'd appreciate any thoughts on the Fumoto valve. Any cons? Recommendations for the best 108 model for the '17 turbo Forester - long, short or no nipple - or new SX?
Also - what might a likely dealer reaction be to the Fumoto if I decide to have an oil change done by the dealer? Fumoto indicates several companies have considered a Fumoto valve a "genuine part' or some such designation - but I didn't see Subaru among them.
Could a dealer claim it invalidates the factory warranty?
Thanks for your thoughts.
Happy Holidays to All!
So, I'd appreciate any thoughts on the Fumoto valve. Any cons? ...
Also - what might a likely dealer reaction be to the Fumoto if I decide to have an oil change done by the dealer? ...
I've used Fumoto on 2 cars and really liked it. Could change the oil easily and almost mess-free - which lead to more frequent oil changes and would do the oil filter every 2nd change.
I sometimes had a dealer change the oil with Fumoto valve in place - and never a negative comment or note made on the paperwork.
