2006 Forester XT Limited 4EAT
Blouch install instructions says on line # 12
Before connecting the oil drain line, crank the engine without firing until a steady stream of oil flows from the turbo oil drain port.
How can I do this short of unplugging the fuel pump? I found not fuse for the fuel pump.
Help and smartass remarks are always appreciated!
99 UK S-turbo
Man how the heck do you do that, only way to disconnect the drain hose easily is to pull the turbo!
Simon
Discussion Starter · #9 ·
Simon
Yeah, I'm probably not going to be doing this strictly by the book. I think I might be able to get the lower oil drain line off the engine though. We'll see....
At least with my '07 FXT, holding the go-pedal to the floor when cranking the engine places the ECM in "flood mode" which cuts fuel so the engine just cranks but doesn't start. I verified this before I did the turbo swap.
I will follow up on this at the dealership this morning!
Thanks all
