Ok, so I introduced myself in that forum post and I'd like to post here the few problems I have with my new Suby.
I have a good amount of mechanical knowledge, enough to feel very comfortable taking apart the engine to do stuff like head gaskets. I just haven't worked on Suby's before so I'm learning and doing research first.
I just got an 01 Forester S with about 170,000 miles on it and like any used car it does have a few minor problems that I'd like to ask about. It's an automatic, mostly cause it's a car my wife will be using mostly and she can't drive manual :icon_frown:
First, the interior smells like fuel sometimes. I've been trying to find a leak, but can't seem to find one yet. I intent to see if there is an access panel to the tank and maybe just a leaky gasket or something, but we have been BOMBED with snow this week and I haven't been able to get to it.
Next is that the windshield squirters aren't working. The front and back do not work, but when I try to use them the wipers do indeed engage. It does have fluid in it. I'm thinking it's the pump because I can't even hear it engage. But again, I'm new to Suby's and maybe it's the switch??
When starting the car there is a quick grind. IMO is sounds like maybe some type of bearing or something. Not sure on this one, maybe the starter has something loose inside. But she fires right up without any problems. A friend of mine suggested a pilot bearing or something, but he hasn't actually looked at it yet.
I'm all ears to things that I should check on this car. I've checked a lot already and it's a sound car. I don't have a maintenance record to go from so when it warms up this spring/summer I have some work to do. I'm planning on timing belt, water pump, head gaskets and other regular tune up stuff. Anything I should be aware of? The head gaskets are sound right now, but I've read that they can be a problem and so I'm just gonna go ahead and replace them while I'm doing the rest of the work.
Any particular type of oil this 2.5L engine likes? I live somewhere that gets pretty damn cold, but not all that hot in the summer. That doesn't mean that I won't be driving to Phoenix sometimes in the summer so I might just need to have a winter oil and a summer oil. What oil do you guys all recommend? I will be using Suby filters just because I believe in factory filters. I'm a huge VW nut and I always use VW filters when changing oil on my dubz.
I'm open ears to suggestions, comments and the like.
Thanks for reading.
Thanks for reading.
