New owner of a 1997 S/tb
495 Views 4 Replies 2 Participants Last post by  Ryguyry
Hey all,
My name is Ryan came across this forum and decided to join up. I picked up a 1997 Forester S/tb yesterday! It’s got a EJ20G, auto, 80,000kms, WRX suspension swap and a few other minor things. Engine just had a oil change with rotella, the previous owner said this was a good oil for the car and it burns no oil. My intentions buying the car was not to modify it but to keep it reliable. I have a 2016 Tundra work truck but wanted this for road trips and camping.
I have done some searching on various forums and have not found a “new owner maintenance guide”
After my inspections of the vehicles the only thing I could see it needing are :
Front Brakes pads - Have read that the part for these are the same as a 1994 legacy turbo... thoughts?
ATF change - Not a flush but a drain and fill. Appears it hasn’t been done, the fluid is still red but starting to dull in colour. Thoughts on what fluid to use?
Spark Plugs - No records of these being changed anytime. Thoughts on that?
Air filter and cabinet filter - Part numbers?
Throttle Body Service - pretty straight forward
I’ve been looking for the factory maintenance schedule with no luck. Is there anything else I should think about replacing due to the kilometres on the car? The car came with all the manuals but I don’t read Japanese. Besides those things the car seems solid. No rust and the body is 9/10. I’m aware the timing belt will need to be done at some point too. Look forward to learning more about the car!
Ryan
Welcome to the forum from Oregon! :biggrin:
The Google custom forum search is pretty good. :wink:
You can ask your technical questions here: Technical Forums and Vehicle Assistance
I did but not much on 1997s I’ll look deeper into the forums tonight 👍🏻
@Ryguyry the main suggestion I had for you is to ask your question in the appropriate technical sub-forum, as not all member view the New Member Introductions. :wink:
Thanks Bobby 👍🏻
