1 - 7 of 7 Posts
MY01 Forester GT 6MT
Gday everyone my names Jacob and i thought i would introduce my forester.
Ive owned it since early 2011 originally as a dayily drive to get to to my apprenticeship, but as i got qualified a company car came along with it and need for the foz was gone ..... so i turned it into a race wagon!!
Coming up to 8 years on its now sitting at 400kw and gets raced a couple times a month 馃檪
Engine :
Bosch 1650ccs
06 spec c big port heads ..with extra porting and polish
T20c 207 been closed decked
Bc 274/278 avcs cams
Bc hd valve springs
Ferra 6000 1mm oversize valves
Later model spec 207 block
Oil phased 79mm stroke crank
Argo I beam rods
Je 92.5mm forged stroker pistons
Cozzy 1.1 mm head gaskets
Arp 625+ studs
Liberty gt sump
Killer b oil pick up
Killer b baffle plate
Turbo smart 40mm gate
6boost steampipe wrx to t3 twist adaptor
Garrett bb gtx3076 .82 rear with 4in antisurge front housing
Kando el headers
Custom 3" straight thru exhaust with x-force cannon
04 sti manifold with tgv deletes poet matched and manifold pnp
Fmic with custom pipes to suit rotated intake manifold
Driveline/ underbody:
2010 Japanese short ratio 6mt dccd gear box
R180 axles
3:54 r180 plated LSD rear diff
06 sti 114.3 hub conversion
Torsen LSD front diff
V6 Ra quick steering rack
Hsd inverted mono pro coilovers
Gold brembos all round
White line 22 and 24mm sway bars
White line rear control arms
Sti Ali front control arms
White line rear strut brace
V6 sti genuine front strut brace
Cusco h brace
Exterior:
Full Foz type c sti body kit
5eigen 17x8 +30 wheels
Genuine Gannador mirrors
Dark tint on rear
02 sti style scoop
Custom mesh grill with f badge
Interior :
Omp first R fixed back drivers seat
Passenger 06 Wrx seat
Omp 3" 6 point harness driver
Rpm 3" 4 point harness passenger
Weld in half cage
2008 sti shifter knob and shifter boot
Rpm corse steering wheel
Forester sti handbrake
Triple gauge cluster in centre of dash
V6 Ra dash with dccd lights
Electrics:
Link g4+ xtreme
Dccd pro universal gearbox controller
G'day Jacob, welcome aboard mate!
1 - 7 of 7 Posts
