1 - 10 of 10 Posts
2003 X
Picking up my 03 tonight, and think it was a good deal. Guy who checked it over for the prev owner said it needs wheel bearing in right front. What's a typical cost for this?
Looking forward to puttin on some miles!
Welcome to the forum from Oregon! :biggrin:
Congratulations on the new Forester purchase! :cool:
I can't help with your front wheel bearing question, I've never had to replace one. :smile:
none none
Its generally around 400 at a shop or dealer. If you are comfortable doing some suspension work, you can pull the knuckle off and bring it somewhere like napa and get it replaced for less labor cost.
Parts are around 100-120 for the bearing and related oil seals. If the hub is scored or damaged in anyway that should be replaced to and is around 100-150$.
Wheel bearings are unfortunately one of the major downfalls of the subaru as they're relatively weak and are of press in design, rather than some others that have simple bolt on bearings.
2003 X
Can you run for a while on the bearings in need of replacement or will it cause a lot of other problems?
By the way, forgot in my haste to mention in the original post that I'm in suburban Philly.
You're likely going to have to replace the hub as well because it will get damaged by the busted bearing, and will cause the new bearing to fail in short order.
In fact, if the bearings are bad enough that they are noisy, it's pretty safe to assume that the hub has already been damaged and will need replacement as well.
1 - 10 of 10 Posts
