Had a problem with taking the rear rotor off, now that is resolved.
Have another question. After I finished replacing all four rotors and pads, I took the car for a test drive. I can feel that the front rotors and pads are dragging/rubbing, and the wheels are warm to touch. I drove some more and stopped to inspect again, now only the front left wheel is warm to touch, and the rotor is the hottest of the four.
The brake fluid was at max in the brake cylinder, so I took some out with a straw. Is there anything else I could try?
Also, when you put the new pads in, whereabouts in the bracket are you supposed to position them? I can slide them back and forth in the caliper brackets about 1/8'' each way. When I put them on, I just positioned them somewhere in the middle.
Thanks.
Thanks.
