Been having some idling and starting issues for about 1 1/2 months now but its not consistent. When idling my RPM's slightly bounce around. Not aggressively but enough to notice it. It bounces around anywhere between 500 RPM and 800 RPM. On two or three occasions my car almost stalled when coming to a stop but never did and that would only last for a couple miles until started running normal again.
The staring is issue is even less consistent. On 4 or 5 occasions my car will have trouble starting up. It'll turn over and eventually die all within a few seconds. But with just some gas while turning it on the problem will go away until it mysteriously comes back again.
With all that being said I have changed my spark plugs and wire, my air filter, and my gas filter. I also cleaned my IAC valve and checked for vacuum leaks. After all that no improvement. My best guesses are that it can be the IAC valve might shot, my fuel injectors are clogged or not working , or I need a new coil pack. If you have experienced similar issues and found a solution please let me know. I don't want blindly change expensive parts. Also if it helps my MPG is seriously suffering.
