When I swapped my wheels over the weekend, I noticed that my rear pads were pretty worn down. They are starting to squeal every so often when I brake. I've changed pads/rotors on more simpler cars, like my corolla and integra, but it seems the forester may be a little more difficult. If I just want to change out the rear pads, will this just be the usual take off caliper bolts, remove pads, compress piston with c-clamp and old pad, spray down with brake cleaner, re-install pads with some anti-squeal lube on the backs, and bolt back on caliper job? Or are there more steps that need to be done? Can any one provide me with a link with a DIY instruction about the rear brakes.
Thanks in advance.
Thanks in advance.
