Really bad experience with Napa Adaptive One brake pads
Well this has been a really bad experience. Six months ago I needed to replace my old Powerslot Cryo rotors and didn't want to spend as much $$ (although they really lasted much longer than they should have). I opted to just get pads from NAPA instead of another set of Hawks and picked up two sets of Adaptive One brake pads along with four Brembo blank rotors.
For the first couple of months everything was dandy, but then I started to develop a shuddering when I was braking. Re-bedding the pads made it go away, but it came back within a week. It was simply an annoyance for a while, but continued to get worse and worse. It seems to be heat dependent because when the brakes are cold they're smooth as butter, but the hotter they get the worse the shuddering becomes, now to the point of making the whole darn interior squeak and rattle.
I'd gone to the dealer for something else and asked them to look at this issue and the tech, whom is also a big part of the local scooby club, said that the rotors weren't warped but it looked like the pads were leaving deposits on the rotors which were sticking as they swept by the pad causing the shuddering.
Then about a week ago I was in highway traffic that was speeding up and slowing down a lot, and the problem got worse and worse. I ended up doing a quick stop, but far from mashing the pedal down, and the ABS started kicking in, the brakes were like having an on/off switch and nothing in-between. After letting them cool down they went back to just being annoying.
I went back to NAPA today to inquire about warranty on the pads and they said they could replace them, but not give me my money back. I already have some OEM pads and I sure as heck didn't want the same kind so I declined on that part. BUT they did agree to also warranty the rotors, so I came home with a brand new set of rotors to replace the funky ones. I had been planning on just having my rotors turned, but really couldn't stomach the idea of turning a 6 month old set of Brembo's so I'm glad I went by the store again.
If the dealer tech's theory is correct, I would stay away from the NAPA's Adaptive One brake pads. They don't brake that well to begin with and, at least for me, leave crap behind on the rotors. But I do have to give props to NAPA for being willing to warranty everything for me if I'd wanted; I was expecting them to say that there was no way to prove it, or I must have raced them, etc... but they went this route without any fight.
Here are pictures of one front and one rear rotor. The marks you see do not so much as think about coming off with brake cleaner, and you can actually feel a texture difference rubbing your finger over them. (pardon the crappy cellphone pics)
