2004 FSTi 6 speed manual
My99 brake caliper bleed nipple size?
Hi does anyone know the size of the brake nipples on my99 foz ...
Are they M8 x 1.25 or M8 x 1.00 ?
Or different? As I've just flushed and bled the whole system and need to change the bleed nipples , there's one not sealing properly as it's old and sucking in air when using the Sealey one man bleed sytem.
Cheers
Andy
2002 SG XT Auto
What's wrong with the old 'up down up down' method with the Mrs?
Then after she can help you bleed the brakes.
:icon_biggrin:
:icon_biggrin:
Pmsl...she said she cba so i bought a friend in Sealey...good sucking action and out performs the missus any day....sitill the the nipple size though :tissue:
00 00 type r, 02x, 03xt Manual
four pots are m7*1 (better with vw s/s extended versions) and so are the rears. The oem front slider calipers, aps, brembos etc are usually bigger at m10x1.
Edit: had a look online and some front sliders are m7*1 also.
Discussion Starter · #5 · (Edited)
Cheers Euan ,have been using some VW bleed nipples and the extended ones at that but thought i'd better use the OEM's but will see what fleabay comes up with pal.
Andy
Edit: found some SS Hel performance to match my pipes at £11.95 ......was looking at some titanium ones but the w****** sell them in threes....duh ....cheeky bampots want us to buy 2 packs at stupid money ..
Anyway thanks again pal .
