Greetings folks
I have recently come into ownership of a 2000 Subaru forester. The story is that a lady blew her idler pully going over a bridge leading to a catastrophic destruction of the timing belt and the timing belt case, rather than deal with this issue she sold it to my stepfather for 100$ (she was in a rush and in a convoy heading across to alberta). Given that it was a construction zone she wasn't going very fast when it blew and also went less than 100 meters from broken to the property i think that might reduce the risk of bad valve damage.
Here she is ladies and gentleman.
Subaru forester 2000 - Imgur
So here are a few questions i have
1. What are the chances the engine already inside will still be alright given the following story if i replace the timing case and idler pulley.
2. In the event that the engine is no good, what engines will be viable replacements, especially the ones with turbo's, keeping in mind that my stepfather is a licensed mechanic and can help doing the work (doesn't have to be a strait bolt on swap). Also what engines would be a strait swap. And or what engine would you recommend. Also approximate horsepower of the options would be nice.
3. Are there anything you see wrong with the car per the pictures i linked you. Also what trim level is this car? It just says Forester on the side.
4. any recommended aftermarket parts to spruce up the appearance or the power.
I would like to get this car on the road as my current car (Mazda protege 2001) is falling apart.
Thanks for your time.
Dan
Dan
