1 - 7 of 7 Posts
2008 SG Model D
So anyways, I go outside this morning to warm up the car like I always do. I go to put the shifter in neutral and it is stuck in first gear and REALLY didn't want to come out of first gear. I tried three times, w/ the clutch in all the way, to pull it out but not too hard. The forth time I got mad and pulled it out. I then, w/ the clutch still engaged proceded to shift through all gears multiple times to check it out and make sure it wasn't sticking anywhere. It felt fine after that so I put it in neutral and let it warm up.
I drove to work and everything seemed fine. I will check it again when I start my car again.
really! is going on? Any insights? Never had this happen to me before.
2008 SG Model D
Discussion Starter #2
Update: Nobody seems to know what is going on. I have started my car plenty today and no reoccuring problems shifting out of first at startup. Hopefully, it was just a fluke that will never come back.
'09 STI
Were you parked on a grade? I could see this occuring if you parked on a grade and had the weight of the car on the tranny instead of the parking brake. Add in some freezing temps and I could see that happening and may explain why there's no lasting effects.
2008 SG Model D
It is on a slight grade but I park there every day and have been through all weather conditions more than once...never had this happen before. Everything seems to be okay now.
2010 dodge caravan auto
mine hates 1st and R when its cold, I've had it stick in 1st a few times
1 - 7 of 7 Posts
