Well here are the numbers:
Compression Dry(psi):
115 130 145 140
Compression Wet(psi):
125 135 150 145
Max difference is 30psi & 7psi is acceptable.
Leak Down Test(%):
65 23 8 10
Was getting sporadic CEL P0301 Misfire Cylinder 1 paired with rough idle. Occurring mostly upon restart after car was already warm. Losing oil as well.
Time to pay the piper, I'll keep this updated as I clean it up.
UPDATE 9/10/10
Had another leakdown test performed by an independent shop. I watched the whole thing to verify the numbers.
Results were 5 18 5 14
Pretty big difference, but still was loosing about a quart of oil every 1.5 weeks. Who knows why Irvine Subaru got such different values.
Pulled the engine and found the culprit to be badly fouled valves and seats on the exhaust ports. All cylinders were also out of round. Plan is, bore the cylinders to 100mm and install Manley forged pistons. Top the deck and heads. Obviously a valve job replacing items as needed, nothing special there.
More to come.
115 130 145 140
125 135 150 145
Leak Down Test(%):
65 23 8 10
UPDATE 9/10/10
More to come.
