2015 FXT Premium
Hey all. I ordered a set of 18x8.5 +44 wheels, but I'm starting to think I made the wrong choice. The wheels are coming from Japan, so I have some time to think if I want to go up to a 9.5.
My end goal is to have a 2-3 finger gap, I'd like to run an aggressive meaty tire, but not have to run a whole lot of negative camber. The recently purchased 15 FXT is my daily, but I plan on doing the occasional autocross day or PDX event.
Bear with me, I haven't had to deal with tires under 285s for the past 10 years lol. Not exactly sure what the widest I can run. From the info I've collected is, 245/50/18 seems to be the most popular choice. Is it at all possible to fit a 255/45 or 255/55 or would that be a bad choice for a 8.5? I have parts collected, will be running Real 441 coilovers, whiteline lower control arms, and whiteline toe arms.
I don't think I want to go up to a 9.5 (+40), from my searches, if you're not going to be flush with the fender or lower, you're going to have a goofy poke stance. I'm not about that life.
Sorry if that's all over the place lol. Any suggestions would be greatly appreciated!
2017 Forester XT
Some pics of 235/50/18 on 18x8 +43. If you want flush, 245/50/18 on 18x8.5 will get you there in my opinion. 18x9.5 with wider 255+ tires and I think you would rub on full lock. At full lock I have barely 1-2 fingers before hitting the wheel well.
To get 2-3 finger gap you’ll need to lower the car more than an inch. Third pic is a comparison between stock and lowered on STI pinks which is just over a half inch drop. On 235/50/18 I have a bit more gap due to a slight smaller diameter.
Hope this helps. Hopefully some others with 18x9.5 +44 will chime in so you have all the information you need.
2015 Forester XT Touring
I don't think you'd have issues with rubbing running 255/45. I've run 265/40 (free tires) on my 18x9. I'm now running 255/45. I run a 40 offset. The 255s are flush with the fenders. If you want to cheat a little you can install the fender covers and that'll give you an extra 2-4mm of poke :)
You can run 255 on 8.5 but you may find a bit of sidewall roll if you do aggressive turns. All depends on the tire as some cheat more than others when measuring.
2018 Touring XT CVT
As you said, the easiest, popular choice.... I'm running a 245/50 currently on a 18x8 et45, lowered on RSRs. Wheel well flush. I also have the OEM wheel well trim so that trims down an extra 2mm of well space if anything. No rub. Sadly, a 245/50 still looks like a bulbous SUV tire. But, also handy here in our crappy roads and occasional ugly winters.
A while back I tested an 18x8.5 et44 with a 255/40 and it fit like a glove, "but that was also before I was on my springs". I would say it would be ok without rub for most daily use. But if you plan to autoX, I think hard cornering "MAY" give you some friction "if lowered". And sadly, fender rolling an SJ in the rear is rather involving work from what I have learned here. Of course, now that I am lowered, I want to revisit a possible 255 setup again.
Remember though, there is some wiggle room with a performance alignment, at the cost of faster tire wear (depending).
GL!
· Premium Member
I always consider the worst case scenario too...and that being you get a flat. The same rolling diameter as stock was important to me in case I need to fit that spare tire. Otherwise I'll be having to call a flatbed and I wasn't willing to go there.
