1 - 20 of 21 Posts
Dyno Test: 01-3rdgr-1.1barFSTigearing
Comment:
JDM Foreseter STi 2.5ltr
Prodrive CIA
3" system with high flow cat
Fuelab Fuel Pressure Regulator
Mocom Racing 740cc injectors
Lateral Performance MD321H
Maximum Wheel Power: 328.8 BHP @ 6175 RPM
Maximum Wheel Torque: 293.8 LbFt @ 3767 RPM
Power to weight ratio: 194.5 BHP per ton
Terminal velocity due to power: 166.7 mph
In Gear Acceleration:
40 - 60mph = 2.3 seconds
50 - 70mph = 2.3 seconds
60 - 80mph = 2.5 seconds
Speed per 1000 RPM:
1st: 5.4 mph
2nd: 8.9 mph
3rd: 13.0 mph
4th: 17.4 mph
5th: 22.2 mph
6th: 28.0 mph
Maximum Speed per Gear:
1st: 38.7 mph
2nd: 62.9 mph
3rd: 92.5 mph
4th: 123.7 mph
5th: 157.9 mph
6th: 199.0 mph
Total Vehicle Mass: 1690kg
Drag Co-efficient: 0.37
Frontal Area: 3.20 square metres
Wheel/Tyre Setup: 225/45/18
Engine Rev Limit: 7100
Test gear: 3
Max Speed of gear: 92 mph
Air Intake Temp: 19°C (66°F)
Atmospheric Pressure: 1.00 bar
Dyno Test: 03-3rdgr-1.3barFSTigearing
Comment:
Prodrive CIA
Maximum Wheel Power: 331.2 BHP @ 6130 RPM
Maximum Wheel Torque: 318.3 LbFt @ 4376 RPM
Power to weight ratio: 196.0 BHP per ton
Terminal velocity due to power: 167.1 mph
40 - 60mph = 2.2 seconds
50 - 70mph = 2.1 seconds
60 - 80mph = 2.3 seconds
Speed per 1000 RPM:
1st: 5.4 mph
2nd: 8.9 mph
3rd: 13.0 mph
4th: 17.4 mph
5th: 22.2 mph
6th: 28.0 mph
1st: 38.7 mph
2nd: 62.9 mph
3rd: 92.5 mph
4th: 123.7 mph
5th: 157.9 mph
6th: 199.0 mph
Test gear: 3
Air Intake Temp: 22°C (72°F)
Dyno Test: 04-3rdgr-1.4barFSTigearing
Comment:
Prodrive CIA
Lateral Performance MD321H @1.4bar
Maximum Wheel Power: 343.7 BHP @ 6003 RPM
Maximum Wheel Torque: 339.7 LbFt @ 4116 RPM
Power to weight ratio: 203.4 BHP per ton
Terminal velocity due to power: 169.2 mph
40 - 60mph = 2.0 seconds
50 - 70mph = 2.0 seconds
60 - 80mph = 2.2 seconds
Speed per 1000 RPM:
1st: 5.4 mph
2nd: 8.9 mph
3rd: 13.0 mph
4th: 17.4 mph
5th: 22.2 mph
6th: 28.0 mph
1st: 38.7 mph
2nd: 62.9 mph
3rd: 92.5 mph
4th: 123.7 mph
5th: 157.9 mph
6th: 199.0 mph
Test gear: 3
Air Intake Temp: 17°C (63°F)
Atmospheric Pressure: 1.02 bar
File attached too as colour reproduction isn't all that
A
Guest
Judging by the bhp per tonne figure these are estimated flywheel figures? if so how did marky9074 manage 400 on the same boost :icon_confused:
WHP ... and it's Marky's , not mine ( The "JDM Foreseter STi 2.5ltr" is a clue ;) )
A
Guest
Sorry, I just realised as I remember you were going to convert the DD files for him :icon_biggrin:
Great power, that must be one hell of a shove in the back :Banane36:
99 UK S-turbo
Hmmmmm..yummy!
Simon
And here's the comparison with the VF41
..now Maidstone
MY14 Audi SQ5 8AT
Thanks Steve, nice to see that the characteristics are the same...
No more Foz !
03 Impreza Sti
:woohoo:
Nice results, can't wait for mine now :Banane08:
Steve - why is it when I click on the pic I also get a rather unpleasant o2 pic of a man squashing a frog ! :icon_eek:
..now Maidstone
MY14 Audi SQ5 8AT
360 whp now... just waiting for the files...
Mad Englishman.
MY06 Forester STi 6MT
So that's over the 400/400 (flywheel) prediction then...?
Isn't that going to melt something :icon_frown:
It has confirmed that the MD321H (as recommended to me by the JGM recently) is the way to go though :biggrin:
Right where's me cheque book......
2008 Forester Cross Sport AUTO
Steve,
the VF41 was what bhp wise v's the new beastie?
I can't see the thumbnail very well.
What kind of money are we talking about on the new Blower?
Thanks.
KInd regards
Alan MaC
Mad Englishman.
Quick Qu; where did the vehicle mass come from - estimated or measured...? If measured was that with someone in...?
..now Maidstone
MY14 Audi SQ5 8AT
It was measured on a weigh bridge if I remember correctly, though Zak has put on a couple of pounds since then...
..now Maidstone
MY14 Audi SQ5 8AT
Steve,
Thanks.
KInd regards
Alan MaC
Alan,
My old VF41 was at 341 IIRC.... (which was 300 WHP on the graph..)
Turbo is GBP1250.00+vat
Cheers.
VF41 is a useful Blower, the new one in a class of it's own.
Regards
Alan MaC
Mad Englishman.
So the 1690 was with human addition..? You got much crap in the back too...?
Just trying to get an idea of the actual standard weight of the FSTI which I always thought was around 1510kg, but that now seems too low.
You pleased with the figures...? What did you wind the boost back a bit and if so what did you settle on..?
..now Maidstone
MY14 Audi SQ5 8AT
I seem to remember that the FSTi kerb weight was 1500kg? That's what it says in the specs... two humans, one driving one tweaking....
Boost is the same, ignition is retarded a bit from what I remember, which did not add up, but the results speak for themselves..
99 UK S-turbo
Probably just run it in now!
Retarding the ignition at non det' limited signs can gain torque if its over advanced, also by avoiding creating knock, you can gain a bit on the bay (as the knock detect will often slightly over retard it) but will loose you power if you ever fill up with a more knock resistant fuel!
Simon
Mad Englishman.
I
So are you keeping it at the 343 ATW, which by my loss figure calcs (1.27) works out around 435 ATF..? If so, isn't that above the supposed danger point for the rods or is it a risk worth taking ...?
..now Maidstone
MY14 Audi SQ5 8AT
No... with the VF41 it was 300whp equating to 340bhp so around 12% loss. This was proven on two independent dynos.
Original map on the MD321H was 340whp, but with new equal length headers and larger tmic and map tweap this is now 360whp at the same boost...
1 - 20 of 21 Posts
