1 - 8 of 8 Posts
2001 Forester Automatic
'01 Forester with about 213k
Engine makes a rattle like noise when revving between 1500 - 2000 rpm or on cold start. Sound appears to be come from around the A/C compress or behind. My brother loosen the belt attached to the compressor and thought it was unlikely coming from it. Here is a video that demonstrates the sound: https://photos.google.com/share/AF1...?key=b1hCU1hUQUFaZXcxTjRmRVhEYUpEcmNNRndQallR
Watch with sound on. No check engine light
Head gaskets were done a little over a year ago. Recently had an o2 sensor replaced (check engine light went on when I had this issue).
Thanks for the help.
Chris
Hey folks, I ended up getting it in the shop. Fortunately it was only the tensioner! This subby will live another day.
Thanks for the help
· Administrator
No, it was the timing belt tensioner failed, so I guess the rattle was a wobbly timing belt. Lucky I didn't destroy the engine getting it to the mechanic!
· Administrator
1 - 8 of 8 Posts
