1 - 13 of 13 Posts
2000 Forester S Turbo manual
why is it that when you do some thing good some thing bad happens :icon_frown:
at a guess im thinking that's a lower drivers side rear control arm!!!? and whats the other thing called with the nut on that connects to the anti roll bar ?
any one have part numbers for both items or recommended upgrade parts?
thank you in advance
Gav
2005 2.0XT Auto
Gav,
Looks like your Whiteline ARB has fractured the rear lateral link drop link mounting point. Needs welding or replacing I guess...
nice one thanks just found the part
Lateral link assembly-rear
20250SA010
and
Link assembly-stabilizer, rear
20470SA011 edit - ive managed to find these from a uk site but no luck with the Lateral links
now i wonder is there an upgraded part for them?
Emeritus Forum Staff
STi lateral links have thicker tabs IIRC
Found them but for 450euro it's a bit much for me at the mo
just looking for two oem parts , going to replace both rear ones
MY11 WRX STi Sedan 6MT
2006 FAXT 5mt
i put on a cbb 25 mm RSB and it did the same thing rip the flang rit e off had a friend weld it back on and reinforced it till i could afford sti aluminum lateral tie bar.
Discussion Starter #8
Great stuff ;) that will hold till after the wedding,
7 weeks left to go don
might replace the Link assembly-stabilizer too why I'm at it
thanks a mill for the info all
2004 fxt A/T
If you weld it you will snap again, I would get the 2004 STI lateral links. They are the same as the one you broke but with a double mounting tab. They should be around the same price as the OEM FXT lateral links. The ones you found I would bet were the aluminum 05+ STI or aftermarket ones (which are much more). If you go back with new FXT lateral links you will definitely need some LLWS (like the whiteline pictured above or equivalent).
If you weld it you will snap again, .
Not necessarily. Were gav's bracket has broken he has a better chance of doing a good repair and fitting the link bracket supports will add strength.
2008 Forester Cross Sport AUTO
Best of luck Gav.
I was in Ireland 2 weeks ago, Dublin/Cork crazy prices my deep respect for you and your fellow countrymen.
Lovely place/folk I hope things get better.
Kindest regards
Alan MaC
Discussion Starter #13
Best of luck Gav.
Kindest regards
Alan MaC
You should of gave me a call buddy I would of met ya for a few pints ;)
1 - 13 of 13 Posts
