1 - 18 of 18 Posts
2001 S Turbo
Thinking of putting in some LED sidelights as the bog standard normal ones do not seem to be that bright compared to other cars.
Anyone have any suggestions for which models work in an 01 fozzie. I read on the web that cars with a CANBUS diagnostic systems do not recognize the LEDs. Is this correct?
cheers
ubdai
99 UK S-turbo
Its rubbish, models with blown bulb detection (which may or may not have CAN) will flag a failed bulb though.
I use multi LED's (about 8) in the front of mine, had them for years, nice bright whitish blue light.
Simon
Simon
Have you got any pics of them?
1997 T/tb
cheers
ubdai
It depends on what the threshold of the CANBUS is set at.
the CANBUS looks at the current draw of each lighting circuit, and if it drops below a certain point, the CANBUS will throw up a failed bulb.
eg.
a standard 5w bulb draws about 450mA and an LED draws only 30mA. so this will flag up a failed bulb fault, even thought the LED may be shining bright.
you can get around this by fitting a resistor in-line before each LED.
OR
there are now LEDs out there with resistors built in especially for CANBUS fitted cars.
SKODA ROOMSTER 07-08+ 501 SIDELIGHTS NO CANBUS LEDS on eBay (end time 23-Apr-10 02:56:33 BST)
Hope this helps
Frazer
1997 T/tb
my car doesnt have bulb fail lights fitted, its too old!.... i have no idea if the new foresters have it fitted, but that is how CANBUS works in a nut shell, regardless of what car /machine it is fitted to....
1997 T/tb
nope, CAN -BUS is nothing to do with bulb fail. It's an internal interface protocol between the various control units...
on the Subaru?.... or in general?
why (in most applications) does "blown bulb" light throw up a Can-bus fail error if it has nothing to do with the CAN-bus?
2015 XC diesel CVT
I'd guess that's possibly on Mutiplexed systems where individual lamp units are addressed over the Bus. Dunno, never seen it.
I've had bulbs out on both the SH and the wife's late 307 (full multiplexed, can/can) and never had a fault. The SH is pretty low-tech tbh, there's plenty data sent around the Bus but I'd reckon the body computer isn't much more than a bank of relays with a fancy driver. It's addressable by SSM3 for configuration, but doesn't output that much data of it's own...
There's certainly no requirement for one, just because the other is present; bulb fail systems have been around since the eighties, CAN-BUS is rather newer.
99 UK S-turbo
Agree with dpm, bulb failure recognition (on the wifes 93MY Celica) ad nothing to do with a car having CAN or not.
CAN is just a communications protocol for multiplexing contorllers onto one circuit for sharing information, bulb failure detect is done on currenta nd on modern cars the bulb failure may be reported on CAN to the IP (instrument pack) to display the information.
As an aside a 2005 BMW 7 series has 3 CAN systems with a total of 128 controllers on them, remembering one controller can output a number of messages, the EMS typically 5 or 6.
Simon
Does anyone have a picture of them fitted to the car and switched on?
The reason I am asking is that some of them do not give a uniform light in all directions but only from the front.
Cheers :)
2018 2.0 XT Lineartronic CVT
I bought some last year with 3 LED on the lamp head (Item number: 350272202382) however one starting flickering after only 4 months. Binned them and bought these . . .
eBay Item number: 280484458578
A bit fiddly to install but fit ok in MY06 XTEn and give better brighter forward light aswell as sideways. No errors or warning lights anywhere:biggrin:
I bought some last year with 3 LED on the lamp head however one starting flickering after only 4 months. Binned them and bought these . . .
fpan . . Trying to send you a link to pic's but system says your inbox is full:icon_question:
1 - 18 of 18 Posts
