1 - 17 of 17 Posts
2006 RX8
Just completed my new Redlinegoods leather shift and emergency brake lever boot installation today, and man what a nice difference! The vinyl cheapo look and feel is replaced with high quality Italian leather. I ended-up just doing the solid black leather with black thread, and it really looks nice without being overbearing. I have a number of installation pictures and will also try and document the install process should anyone else ever decide to do this upgrade.
Jeff :)
Update: Just wanted to let everyone know that the install information is now up on the Redlinegoods website. Considering that, there is really no reason for me to keep all of the pics in this thread any longer so I will be editing as such. Btw- Feel free to give me shout if you have any questions!
Jeff
2006 RX8
Discussion Starter · #6 · (Edited)
Steps of install w/pics
I just recently installed my new Redline Forester leather shift boot and emergency brake lever boot this weekend. Thought I would share the step-through process and a few pics I took during the install. Although this upgrade is purely aesthetic, it really dresses-up the interior of my Forester XT, and I think well worth the dollars and investment in time if aesthetics make a difference to you.
First but foremost, make sure that you have the following items available.
1) Phillips and flat blade screwdrivers
2) Needle-nose pliers
3) Contact cement ( Auto Zone for $2.65 a tube)
Step 1 - Console & shift boot removal
1) Remove the shift knob by unscrewing it counterclockwise, and then push down on the silver retaining ring on the top of the boot to seperate the boot from the knob. Set the knob off to the side.
2) Grasp the back side of the console where the back edge of the boot meets the console. Pull up and the console will come loose at the back. As you pull up on the back, slide the console back and down in the front. You will see a tab on each side at the top and front of the console. Once you have cleared these tabs you can carefully wiggle the console free and then sliding the consol and boot out and off of the shift lever it will come free.
3) Although the console has been removed it will still be connected by several wires. There will be wires connecting to the ashtray light and also to the cigarette/power receptacle. Remove both of these at the connector point on the console, and then set the console off to the side and out of harms way.
4) Turn the console and boot upside down to gain access to the boot retaining clips. They are made into the console and clip the plastic boot ring in place on the front, back, and both sides. Just pry back and pop the shifter boot and its attached boot ring out of the underside of the console.
5) Now to disassemble the stock boot. First remove the vinyl boot from the ring by pulling it loose from the plastic boot ring. It is glued in place, so I would advise using a set of needle nose pliers to get things going. Once you can get a good grip, you can pull the boot loose pretty easily. Keep an eye on which side of the boot ring is up and down for the re-install. Also flip the boot inside out and remove the plastic inner-retainer and the chrome outer ring from the old boot. They are also glued in place as well, but can be pulled loose using care.
Console and boot removal are complete.
2006 RX8
Discussion Starter · #7 · (Edited)
Step 2 reinstalling the new boot-
1) Re-install the plastic inner retainer for shift knob. No glue required
2) Fit the boot around the plastic base ring. Again no glue required but optional I suppose.
3) Re-fit the boot and ring assembly from the bottom back into the cosole making sure the clips securely retain the boot and retaining ring.
4) Re-connect the power connectors on the ash-tray light and receptacle
5) Re-fit the console sliding upper tabs into dash panel. Press console into place, making sure any excess boot material is tucked inside.
6) Re-fit the chrome ring using contact cement
7) Re-install knob of choice and slide plastic boot retainer up on knob barb.
8) inspect for fit and electircal function of re-connected console lamps
Boot install completed!
2006 RX8
Discussion Starter · #8 · (Edited)
Install steps for E-Brake boot
Step 1 - Lower console base removal and stock e-brake boot removal
1) Remove shifter console per earlier shift boot install instructions
2) Open the console top and remove the two black philips screws at the back of the console base. Also remove the two black phillips screws at the front of the lower console.
3) After removing all four philips screws, you will need to pull up on the emergency brake handle, and unsnap the snap on the factory boot under the handle. For easy removal access, pull the console base up in the front on each side a little, and then in the back as well. Once you have the back freed-up you can tilt the front up to clear the climate controls and then carefully slide the console forward and up over and off of the emergency brake handle.
4) Before getting too carried away, the seat heater connectors will need to be disconnected before being able to remove the console. They are color coded to the receptacle so there is no worry concerning getting them reconnected properly. These require a simple squeeze in to remove.
5) Pull lower console and stock e-brake boot out of car and move to bench location to finish removal of boot.
6) Pop retainer clip on underside of the E-brake handle slot. This is the plastic retainer that holds the e-brake boot in place. Once unclipped, pull the clip and boot out of the lower console housing.
7) Pull factory boot off of black plastic retainer/clip.
Lower console and factory e-brake boot removal completed !
2006 RX8
Discussion Starter · #9 · (Edited)
Step 2 - E-brake boot and lower console re-installation
This is by far the toughest part of either boot installation.
1) Once factory boot has been removed from the ring (again the boot is best pulled loose using a set of needle-nose pliers to get it started), then you need to get the contact cement and new e-brake boot ready.
2) The new boot is a tight fit, and the curve of the plastic retainer piece makes the install a three-handed job.
3) Dry fitting it is a good idea, then once you are satisfied with how the boot will sit on the retainer ring, use the contact cement on the plastic retainer using it along a portion of the ring at a time to ensure the cement doesn't set-up before installing the boot.
4) Beginning at the front end, I glued the front edge, and then part of one side in place. I palced the rear edge of the boot over the retainer, but did not glue yet. The e-brake boot will be installed flush with the plastic retainers edge with no excess hanging over. The cement set-up fast, but you should allow it to become tacky, then press the boot in place and hold till set. This doesn't take too long.
5) Continue to glue the other side from the front to the middle, and hold until set.
6) Pull the rear of the boot up and off carefully and place cement on the back edge and back to center sides of the retainer. Reposition the back of the boot and then work down the edges from the center of each of the sides to the rear. Let dry.
7) Reinstall the new boot and retainer clip back into the console and clip securely. Its tight becasue the leather boot is thicker than the vinyl stock boot.
8) Reinstall the new e-brake boot over the e-brake handle (remember to unhook the Velcro at the boot edge to provide enough room for the handle to go through), reconnect the two seat heater connectors, and finally lower the console back into place.
9) Screw the four(4) black philips head screws back into place to retain the lower console and the reinstall the shift boot console as noted in the shift boot installation instructions above.
Leather E-Brake boot installation complete!
Hope I didn't miss anything about this install. As mentioned earlier the boot is from Redlinegoods. Excellent products and great customer service with a personal touch!
Jeff
2006 RX8
Discussion Starter · #11 ·
These boots have been specifically designed for the Forester/Forester Xt. There is no specific detail on the Redlinegoods website yet, but I owe Redlinegoods the same info I posted here so they can show the product as available. It was probably backwards, but you guys were first.
Jeff
I can't wait to see that. How do we order if its not on their website? Just call?
N10S said:
$30 for each boot I think, don't hold me to that though. I am also getting ready to ship my console top to them to have it covered as well. This is around $50 I believe.
2006 RX8
Discussion Starter · #15 ·
I was just looking at the website and it looks like the general pricing theme is there based on the other applications. A little more expensive to buy each boot individually and a saving if you buy both.
I tried e-mailing my install info/pics to the owner, Maciek, last night, but had trouble sending the files. I will try again later tonight when I get home. Until then, if you are interested just email him and I am sure he can take care of you.
Jeff
Skeptic
2004 XT
Nice write up! Could you also ask them about making a cover for the armrest extension lid/cover? That hard black plastic is the worst looking/feeling thing in my interior (IMO). It would be nice to get some real leather under my elbow.
thanks,
Scott
1 - 17 of 17 Posts
