1 - 20 of 39 Posts
The Sub kit guy
2005 Forester XT VF39
Both Tre36 and myself are running those with Swifts. I have 1/4" spacers in the back but he doesn't. Can't really tell any difference between th elooks of the two cars but it definitely rides better than stock.
The Sub kit guy
I run the Paranoid Fabrication ones and I got them in HDPE. I bought them thru RS25 and I got the 02/03 Impreza ones, but the 04-07 Imprez ones work fine too. You could probably use the 3/8" or even the 1/2" ones if you don't run a rear strut bar. I have a Whiteline quick release bar and the 1/4" were probably the thickest I could usse and still thread the bar on securely.
Got a saggy butt? I have a fix - RS25.com: Subaru Impreza GC8 & RS Forum & Community
2008 SG Model D
Does the 1/4" spacer make it the same height as the stock struts with swift springs? I just don't want to jack the rear up any higher b/c the swifts already angle the car down more than stock which increases the front downforce due to the front lip spoiler.
The Sub kit guy
To me, GR2s are the exact same size as the OEM struts. I use the spacers because even though the car sits level on Swifts, the way the fenders are cut it made it look like the rear had slight sag.
Super Moderator
KYB-GR2 with Swifts here as well - no saggy butt on Subed. At first I did find the ride a tad bouncier than on stock struts, for some reason, but it's grown on me now.
2008 SG Model D
Discussion Starter · #9 ·
Okay, thanks! Can't wait to get them on!
2005 Forester XT 4eat
I have the GR2s with the Swifts. Most people (even some of you guys) can't tell that I have modified suspension when you look at it. It also rides very smooth. I couldn't really tell the difference between the stock dampers and the GR2s because I swapped my dampers at the same time as the springs, but the GR2s are a better match for the Swifts than the OEM dampers were with the OEM springs. If you want a very comfortable ride without any silly rear end wiggle coming out of tight turns, then this is a very nice setup.
2009 Outback XT-B 5MT
I got the GR-2's for my SF from AJUSA. Great company. They held up great to the lift, and Kamil can tell you how they are doing now.
2004 FSTI automatic
How much harsher are the group-n tophats? This is my daily driver and I don't track my car. I want better handling but still retain a compliant ride comfort.
I only did the fronts, b/c I was worried about harshness too, and didn't want to jar the baby around. But they aren't harsh by any means...I thing having a 40 series tire is harsher..lol. If I were to do it again, I would get the rears too...but my set-up is about as stiff as I would like to go, considering we road trip it, and it is my dd as well.
As long as your struts are doing their job, the Group N top hats shouldn't make the ride any more rough. The roughness really has to do with the right dampeners for the right springs.
1 - 20 of 39 Posts
