1 - 2 of 2 Posts
2004 foresterXT AT
hi everybody,
im new to this forum and i was wondering if it is possible to do this following setup on a 2006 Forester ?
-raised kings springs + 1" spacer from Subtle ?
-what is the largest size tire to run ?
-anybody has this set up or similar on a 2006 or newer Forester?
i will be doing some challenging off pavement driving and want the Forester to be set-up right.
thank you all,
oliver:icon_wink:
Hi Oliver
Raising the suspension in this manner won't allow a much larger tyre because the spring perch remains in the same place. Otherwise, you should be able to lift as suggested.
1 - 2 of 2 Posts
