Hello,
I drive a 1999 Subaru Legacy Outback with a manual transmission. The key is locked in the ignition, and I can not get it out. I've tried wiggling just about everything I can, and this key just will not come out. It is stuck acc spot. The car can still be turned on and drives.
I've read through the owner's manual, and it says that there is a Key interlock release in the steering column. I've unscrewed the cover under the steering column but can not find any key interlock release. The manual does say that the key interlock release is only for Automatic Transmissions, but I drive a Manual Transmission.
Every site I've found online only solves this problem for a AT not MT. Would anyone be able to help?
:chair:
~Thank you.
:chair:
~Thank you.
